Thread: Pump sizes
    May 2011
    Default Pump sizes
    I'm curious. Why are lower HP pumps more expensive than higher HP pumps?
    AG 7600 gallons, sand filter, 1.5 HP Hayward pump (1 speed), K-2006 test kit
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump sizes
    First, you need to be careful when comparing pump prices with the nameplate HP. For example, within the same pump line, a 3/4 HP full rated pump (high service factor) is actually the same pump as a 1 HP up rated pump (low service factor). The nameplate HP may be different on each pump but the total HP (THP) is the same for both pumps and their head curves are the same. However, this doesn't mean the pricing has to be the same. Often times the up rated pump has a lower price. In general though, the cost of manufacturing a higher THP pump should be higher but supply and demand market forces will influence the price as well.
    Mark
  1. Freeform pool sizes
    By SCRUBIN in forum In-Ground Pool Construction and Repair
    Last Post: 05-30-2013, 01:18 PM
  2. New pool build -- pipes and pump sizes
    By jasontx in forum In-Ground Pool Construction and Repair
    Last Post: 01-15-2007, 05:57 PM
