Re: Pool Nub
Since the 25th I've run my cleaner 2X and programmed my SWCG to not run between 10P & 6A & NOTHING else. Pool has been used every day by 3-6 people. Here's the latest as of tonight:
FC: 6
CC: none detectable
pH: 7.6
TA: 120
Hardness: 150
Couldn't test for CYA because I ran out of reagent - the K-2006 only came with enough to test CYA 6X. Need to order more. At any rate, water is crystal clear, looks and feels great. Can barely even tell it's salt water - & there is no Chlorine smell. Based on previous advice, I want to get CYA up a bit, but other than that, I'm down to what I hope to be my last couple of questions for a while. Is it now possible, chemistry-wise, for me to program my pump to shut down along with the SWCG (10PM - 6AM)? Anything special to consider for doing so?
Again, thanks for all the advice - it's been a great help!
28K gal Wilbar 33' round x 54" AGP; CircuPool RJ60 SWCG; 1.5 HP motor/pump; 150 sft cartridge filter; PF:4.3
