Re: Pool Nub
Started SWCG this morning before I left for work. When first started, it is programmed to run on "super chlorinate" for three hours. Got home this evening to crystal clear water, and was finally able to do a full test set using the K-2006. Here are the results:
FC: 9 ppm
CC: 1 ppm
TC: 10 ppm (Did a second check using OTO and came up with about 4 ppm) Up until this point, when I get home, there is typically 0 ppm Cl in the evening (left over from bleach add night before & no CYA)
pH: ~7.6 (1 drop of acid took it to ~7.4)
TA: 120 ppm
Hardness: 130 ppm
CYA: ZERO (hadn't added any at this point)
SWCG manual calls for the following:
FC: 1-3 ppm (I'm out of spec high)
pH: 7.2-7.8 (though the manual also says these pools tend to settle out around 7.8)
TA: 100-200
Hardness: 200-300 (I'm out of spec low)
CYA: 30-60 ppm (I'm out of spec low)
I used bleachcalc and came up with ~7 lbs CYA for a 30 ppm move. However, I only added 3 lbs tonight.
Questions:
1) My SWCG is oversized, I assume after tomorrow, I will need to dial it back somewhat. True?
2) Is the hardness level a concern? If so, what should I do?
3) If bleachcalc is correct, I should see ~15 ppm CYA tomorrow. Correct? Should I then make another add to slowly get into spec? Once I'm there (30-60), what is ideal?
Thanks for all the help. This site is great. I'm already getting glazed over stares when I tell people I'm using the BBBSWCG method of pool chemistry control.
28K gal Wilbar 33' round x 54" AGP; CircuPool RJ60 SWCG; 1.5 HP motor/pump; 150 sft cartridge filter; PF:4.3
