Re: Laid it to it with the bleach, now pool is a milky white color
I think i have killed all the algae. I did the floc test using your formula. It didn't do much. I did some separate test in smaller clear drinking glasses. If I overdose the flocculant, it really cleared up the water. It left a white creamy ewwie. Gueey. Substance on the bottom of glass. I assume the is the cloudy murky stuff in the water all condensed together
I flocked the pool and waited overnight with pump off. I didn't notice any difference. I did another K-1000 test this afternoon and it showed no chlorine and still the phone was super high. It was a darker color than highest setting on test tube, so I guess i need to add some acid.
The flocculants say that they need a 7.2 Ph to work properly.
I floc. The pool again this afternoon. Going to let it sit overnight again.
Any suggestions?
In Ground, 6,900 Gallon Gunite pool with tile trim, Haywayd EcoStar SP34000VSP Variable Speed, Aquarite 25k SWCG, North Florida
