Results 1 to 9 of 9
Thread: Order of adding chemicals - question
    Jun 2011
    Northern VA
    Unhappy Order of adding chemicals - question
    Order of adding chemicals - is the only reason to add chlorine before the stabilizer the concern of having to use more chlorine if you are having a possible problem?
    If someone added stabilizer and then a little later the ph down but didn't realize that they should have added the chlorine first, can they go ahead and add the chlorine after that - since the pool needs chlorine?
    Appreciate any thoughts on this so I can go put chlorine in the pool...
    Renee
    27 ft x 52 in AGP
    Hayward Power flo LS 1.5 hp - Hayward model s180t sand filter
    27' round 17.2K gal AG pool; hand fed; Hayward model s180t sand filter sand filter; Hayward Power flo LS 1.5 hp pump; 24/7hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; orig. truck but use well to resupply; summer: ; winter: ; ; PF:7
    Default Re: Order of adding chemicals - question
    Your post is a little confusing to me. You can always add chlorine. But, it doesn't always have to be first. I'm not sure I understand your question. Are you talking about a freshly filled pool and needing to get chlorine in there quickly before it turns green or ?? Please clarify for me.
    Jun 2011
    Northern VA
    Thanks for the response Watermom, let me try again.
    When the pool needs multiple chemicals I was wondering if there was a preferred order. What I found when I did a search on the forum was that if you need stabilizer and chlorine that the chlorine should go in first and then the stabilizer. I needed stabilizer, chlorine and Ph down and was wondering what order they should have been added.
    27 ft x 52 in AGP
    I would take the pH down first, if you're planning to shock, because high levels of chlorine give falsely high pH readings. If you're not shocking, then you can work on chlorine and pH at the same time. You can goahead and add stabilizer as soon as the green is cleaned up-- the sooner the better.
    Jun 2011
    Northern VA
    Thank you Aylad!
    27 ft x 52 in AGP
    Jun 2011
    Northern VA
    one more question, if the pool had been green and stabilizer was added first what problems might have occurred?
    Luckily I have been adding lots of bleach but it was disappearing quickly so I added stabilizer last night.
    Thanks Again,
    Renee
    27 ft x 52 in AGP
    No problems. Having added stabilizer just means that your needed chlorine levels will be higher since there is a correlation between the two. (You can read about it in the Best Guess Chlorine Chart in my signature below.)
