I would take the pH down first, if you're planning to shock, because high levels of chlorine give falsely high pH readings. If you're not shocking, then you can work on chlorine and pH at the same time. You can goahead and add stabilizer as soon as the green is cleaned up-- the sooner the better.![]()
