Results 1 to 10 of 15
Thread: Upsize Pump And/Or Piping?
    May 2010
    Default Re: Upsize Pump And/Or Piping?
    Does 15-16 lbs of backpressure with the filter on either Backwash or Rinse tell you anything? Do those readings somewhat correspond with your projected pressures? (See below, also.)
    All the above ground piping was replaced last year as part of a complete refurb. (Piping size was kept at 1.5 inches.) The backpressure didn't change much from before the refurb.
    What I have downstream from the heater bypass is a Nature2 cartridge holder (G Series, part of original system, currently empty but used previously), a Jandy check valve (2 years old) and a Rainbow chlorinator (part of original system). There is a 1.5 inch manifold with one 1.5 inch branch to the pool returns and a 1.5 inch branch to a water feature. Underground piping is, of course, a mystery.
    The Jandy check valve has unions, so I removed it and left the pipe open at that point. With the heater bypassed I got 13 lbs of backpressure and with the heater in circuit I got 20 lbs.
    I then reconnected the upstream side of the check valve, but left the downstream side open. With the heater bypassed I got 17 lbs. of backpressure and with the heater in circuit I got 23 lbs.
    I appears that the check valve is contributing 3-4 lbs of backpressure.
    Visual inspection and manual operation of the check valve showed apparently normal operation, although the spring-loaded flapper does seem fairly strong.
    According to the Jandy spec sheet, the check valve is supposed to cause no more than 0.5 lbs of pressure drop (1 ft of head) up to 50 gpm and no more than 1.0 lbs of pressure drop (2 ft. of head) up to around 90 gpm.
    With the check valve fully reinstalled, I recorded pressures with one or both of the 1.5 inch pool return and water feature lines turned on. Normally I have the water feature valve partially open.
    Here is the various data that I have, sorted by backpressure:
    Through filter, Nature2 (empty), open pipe - 13 lbs ****
    Through filter, backwash - 15-16 lbs
    To filter, rinse - 15-16 lbs
    Through filter, Nature2, check valve, open pipe - 17 lbs ****
    Bypass filter, through Nature2, check valve, chlorinator, pool return (full) + water feature (partial) - 17-17.5 lbs
    Through filter, Nature2, check valve, chlorinator, pool return (full) + water feature (full) - 18 lbs
    Through filter, Nature2, check valve, chlorinator, pool return (full) - 20 lbs
    Through filter, Nature2, check valve, chlorinator, water feature (full) - 20 lbs
    Through filter, heater, Nature2, open pipe - 20 lbs ****
    Bypass filter, through heater, Nature2, check valve, chlorinator, pool return (full) + water feature (partial) - 22.5 lbs
    Through filter, heater, Nature 2, check valve, open pipe - 23 lbs ****
    Through filter, heater, Nature2, check valve, chlorinator, pool return (full) + water feature (partial) - 23 lbs <normal operation>
    The check valve would appear to be a problem. Are there any more smoking (or bubbling) guns hidden in all this data?
    If replacing the check valve doesn't allow the chlorinator and water feature to (again) function with the 1.5 hp Super Pump on low speed, do you think that there would be a benefit from changing the above ground piping to 2 inch? (The chlorinator was just barely working at low speed.) Would the overall performance of the system improve? Would the pump run more efficiently? The three 1.5 inch suction lines could be put into a 2 inch manifold. The 1.5 inch pool return and 1.5 inch water feature line could come off a 2 inch manifold.
    Thanks again.
    15K gal IG pool; 13 yr old 2spd 1.5HP Hayward SuperPump w/ rebuild motor; 24" Tagelus TA-60 filter w/ zeolite media ; heat pump; chlorinator.
    Pump located ~4 ft abv water level; water features ~3 ft above water level; all plumbing 1.5"
    mas985's Avatar
    Pleasanton, CA
    In backwash mode, I would expect about 5 PSI, not 15 PSI. But I don't know what you have on your backwash plumbing either.
    But in normal mode, you get 23 PSI, I would expect 15 PSI and without the heater you get 20 PSI and I get 11 PSI.
    There seems to be a 8-10 PSI delta.
    Does your pressure gauge go to zero when the pump shuts off?
    If so, this tells me that perhaps there might be an issue with the backwash valve.
    Mark
    May 2010
    I think we are at the endgame here.
    First, the answers to your questions. The backwash plumbing is one 90 degree elblow and 10 ft. of 1.5 inch flex. The pressure gauge does go to zero when the pump shuts off (and was replaced, see below).
    The most recent diagnostics and changes:
    I completely replaced the (Tagelus) multiport valve. (I disassembled the valve, checking for blockage. There wasn't any blockage, but there were small rocks (!) embedded in the (non-replaceable) spider gasket. It was cheaper to replace the whole valve than replace just the diverter.)
    I installed the new multiport valve first with the old pressure gauge and then with a new pressure gauge. There were only minor differences in pressure readings between the old and new multiport valve and the old and new pressure gauge.
    I temporarily removed the flapper from the Jandy check valve, but there was no change in backpressure.
    Reminders: All piping is 1.5 inch. All valves are 2 inch valves with reducing couplers. Pump is a 2-speed, 1.5 hp Hayward Super Pump. Problem is that at low speed, with the heat pump in circuit, there is not enough pressure/head to operate the water feature or the chlorinator. The water feature and chlorinator will function at low speed with the heat pump on bypass. The water feature and chlorinator work fine with the pump on high speed and the heat pump in circuit.
    Summary of backpressure readings:
    To filter, to waste - 8-9 lbs.
    To filter, to rinse - 14-15 lbs.
    Through filter, to backwash - 15-16 lbs.
    Through filter, Nature2 (empty), check valve, chlorinator, pool returns (full) + water feature (full) - 18 lbs.
    Through filter, heat pump (incl. 60 ft. of pipe out and back), Nature2 (empty), check valve, chlorinator, pool returns (full) + water feature (partial) - 23-24 lbs.
    There doesn't appear to be anything "wrong" with any particular component of our system. The addition of the heat pump and extra piping made the performance of the system marginal last year and, for unknown reasons, sub-marginal this year.
    I believe I have three options:
    Status Quo - I rewired the (mechanical) controller so that the timer turns the high speed pump on and off. There is no upfit cost, but there is probably extra cost for electricity. I could run the calculations and see if I could operate the pump for less than the current 12 hours a day.
    Replace all above ground piping with 2 inch pipe. Benefit would be somewhat reduced since the underground return to the pool is a single 1.5 inch pipe and the underground water feature line is a 1.5 inch pipe whose valve is only partially opened.
    Replace the Hayward Super Pump with a new pump, probably variable speed/flow or high-efficiency. Most of these new pumps require 2 inch piping. I could upfit the piping to 2 inches and then, if still necessary, replace the pump now or later.
    Do you have any other options to suggest? What would be your recommendation or ranking among the options?
    Thanks again.
    mas985's Avatar
    Pleasanton, CA
    Actually, your problem is just the opposite. You have too much pressure/head which is reducing your flow rate. I think you meant that you want more flow rate not pressure.
    There is clearly an object(s) that is causing fairly high head loss. When you bypass both the heater and the filter, the pressure is still pretty high. Plus the pressure is high when backwashing. It just could be you have a lot of high head loss components.
    I would not want to guess at a two speed pump size because right now there are too many unknowns. A VS would allow you use trial and error to hone in on the appropriate RPM and flow rate to minimize energy costs.
    Mark
  1. Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    By ChuckDavis in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 04:56 PM
  2. Pump and Heater Piping
    By MaxxFusion in forum Pool Equipment & Operations
    Last Post: 05-06-2009, 10:43 AM
  3. Piping filter/pump/heater. Any tips?
    By cruzmisl in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2007, 11:52 AM
  4. Pump return piping and "looping"
    By eljefe281 in forum Pool Equipment & Operations
    Last Post: 08-09-2006, 11:56 AM
  5. pump piping
    By sulconst2 in forum In-Ground Pool Construction and Repair
    Last Post: 05-11-2006, 01:41 PM
