Thanks. The main reason I'm going with pucks for now is that I have read around here somewhere that a new pool benefits from the ease of pucks because you don't have to worry about high CYA levels the first year. Once the SWC comes on line I was planning on setting the CYA level around 40-50ppm even though the SWC manual states 60-80ppm (why? I have no clue. Perhaps it puts less strain on the SWC?) and then the occasional shock with Chlorine. Perhaps an automatic shock once a week is overdoing it, but where I live is VERY VERY hot in the summer, a day under 100 degrees in July is hard to come by. Wouldn't this kind of heat maybe require more frequent shocking?
