Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: FC and TC Too High and won't come down
  1. #21
    Default Re: FC and TC Too High and won't come down
    Ok.
    + CYA>100 => keep your chlorine at 7 ppm or above.
    + Do NOT add any alkalinity plus or calcium hardness increase type products.
    + Give us an inventory on what chemicals you have left. I assume you have, or will return the tabs. You can use the 4n1, but because of the alum you may want to add it via your skimmer. Just make 110% sure that there are NO tabs in the skimmer, a feeder or anywhere else where the shock can touch them. Just make sure your chlorine stays above 7 ppm.
    + Do you have access to pool store liquid chlorine (commercial bleach) or cal hypo in a 50 or 100lb container?
  2. #22
    By the way, having a CC reading of 0 is good! That is what you want!
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 11:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 05:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 01:09 PM
