Re: Steps for a 54" wall above ground pool?
Thanks, guys! I think I have decided to try and find a solution using my existing steps since I haven't found any steps online that are high enough. I ordered 2 of the step risers. I am going to use nylon bolts to attach the two of them together and then more nylon bolts to attach this double riser to the bottom of the steps. This will make the bottom step pretty high off the bottom of the pool floor (it is currently 11 inches off the floor but with two 4-inch risers attached it will be 19 inches off the floor), but that shouldn't be a problem since you are swimming and buoyant. I think this will work --- maybe. I have consulted with my co-moderator Al (Poconos) and he also thinks it is feasible. It is worth a try. It never occurred to me that my current steps wouldn't work with the new pool when I ordered it, but I'm still glad I went with the higher wall pool.
