Results 1 to 10 of 16
Thread: Opening with very high ph and mustard algae
    Feb 2012
    NJ
    Default Re: Opening with very high ph and mustard algae
    Thank you water mom and doc. I am doing the suggestions you gave me and will do the reading again as I just got the filter going and added bleach.
    I just paid the $14 to join so I do thank you for your help and hope to use this forum often.
    52K gal IG pool - Jandy 2.5 HP Uprite MHPU Series Pump - Hayward S270T2 High Rate Sand Filter - attached spa - PF:2.3
    24'x50' free-form 52K gal IG pool; Liquid Chlorine or Bleach; Hayward sand filter; Jandy 2 1/2 HP pump; 8/10/2012hrs; Taylor 2006 ; well; summer: ; winter: ; iPad; PF:2.3
    Feb 2012
    NJ
    An hour after adding chlorine and bleach, my chlorine level is:
    FC. 9.5
    CC. 2.5
    This was my first time using the k-2006c so I will have to learn how to use it correctly.
    I guess I will see how things look in the morning.
    Thanks!
    Get some acid -- you need to get the pH down below 8.0!
    Also, we'll need make/model on the pump and filter in order to offer better advice.
    Feb 2012
    NJ
    Water looks 100 percent better today and is very cloudy but no longer disgusting. I will get reading after work and buy acid after work. I ran the filter on recirculate last night but changed to filter this morning.
    Hayward Sand Filter. S270T2. Pro Series High Rate Sand Filter
    Jandy 2.5 HP Uprate pump. MHPU Series - could not find model number yet
    Thank you again for helping me!
    Feb 2012
    NJ
    Here are the readings I got today. Put in Tabs in chlorinator as well as lots of bleach and liquid chlorine. Put in acid today as well.
    FC 2.4
    CC .8
    TA 70
    PH 8
    Calcium 200
    Given your low TA, I wouldn't try to push the pH below 7.6 right now. Have you tested your stabilizer level? That's critical to know.
    Feb 2012
    NJ
    Cya is 40
