Results 1 to 10 of 16
Thread: Opening with very high ph and mustard algae
    Default Re: Opening with very high ph and mustard algae
    Then, till the algae is gone, try to dose to 15 ppm (15 gallons of 6% bleach) and repeat before levels go below 5 ppm.
    Feb 2012
    NJ
    First of all thanks for all your advice
    Was away for 5 days and had to do what I could before I left.
    FC and CC need major dose when sun goes down
    ph 7.4
    TA 50ppm
    CH 130ppm
    CYA - The black dot does not disappear even after I filled the tube to the top.
    Thanks!
    52K gal IG pool - Jandy 2.5 HP Uprite MHPU Series Pump - Hayward S270T2 High Rate Sand Filter - attached spa - PF:2.3
    24'x50' free-form 52K gal IG pool; Liquid Chlorine or Bleach; Hayward sand filter; Jandy 2 1/2 HP pump; 8/10/2012hrs; Taylor 2006 ; well; summer: ; winter: ; iPad; PF:2.3
