Thread: Hayward EC50 - Vac to Waste
    May 2012
    Michigan
    Default Hayward EC50 - Vac to Waste
    Hi all! I just purchased an EC50 D.E. filtering system with powerflow matrix pump, and I had a question: Because I have a large buildup of sediment and algae, is it possible to vacuum to waste with this model of filter? Do I need a shutoff valve on the return line to force the water out the drain port? Will doing this damage the flex-tubes? Any information regarding this subject would be greatly appreciated.
    I have a large doughboy oval pool (42'x20'), about 22,000 gallons. I just opened it and shocked it today on the 20th.
    Thanks!
    Default Re: Hayward EC50 - Vac to Waste
    I don't think so. If Waterbear sees this, he can answer for certain.
    What you might want to do, instead, is use a long vac hose to vacuum by siphon. It's a little slow, but won't stir up the bottom, and won't mess up your filter.
  1. Backwash, rinse or waste cycles loose pressure on hayward sand filter
    By Teresa Alsop in forum Pool Equipment & Operations
    Last Post: 06-14-2013, 05:04 PM
  2. Vacuum to waste?
    By jd.pool in forum Dealing with Algae & Slime
    Last Post: 07-12-2006, 12:47 PM
