Re: pH Testing
The better pH reagents such as the one in Ben's kits and the Taylor reagents already contain a chlorine neutralizer in them at a level that won't have an appreciable effect on the pH. Adding extra could cause the pH reading to become higher than it really is. Some of the cheaper 4 and 5 way kits advice you to add a drop or two at high chlorine levels since their reagents do not contain a neutralizer. An extra drop or two with a reagent with the neutralizer in it might help you get a better idea of where your pH is but the reading is still going to be off.
If I am not mistaken both Ben's and Taylor's reagents will give accurate readings up to 15 ppm chlorine.
