Results 1 to 10 of 16
Thread: Filter Cleaning - Unable to close the lid
    Default Re: Filter Cleaning - Unable to close the lid
    You'll need to find and post the make / model of the filter. You can search for it, via the Google Custom search link in my signature, but even better, you can go to Hayward's site and download a manual. Once we know exactly which filter it is, there's a fair chance we can help.
    rkrgk is offline Subscriber Thread Analyst rkrgk 0
    May 2012
    Phoenix, AZ
    The filter did not have a label, but the grids are 30 inches long, so I assume its a 60sqft model. I am uploading a picture of it here. Based on that information, I assumed that the filter is DE6020 and I did check the manual in haywards website and it says "Use ONLY Hayward clamp system components; DEX2421JKIT clamp system, DEX2421J2 nut/bolt assembly,
    DEX2422Z2 metal reinforced seal. Non-Hayward clamp components may fail in use and cause explosive
    component separation. Verify that upper and lower filter bodies are properly secured with the filter body clamp.
    Never rely on hand tightening the clamp nut to the clamp bolt. Using a ¾” socket on a torque wrench, torque clamp
    nut to clamp bolt to 150 inch-lbs. Verify that the filter manual air relief body is in the LOCK position, and no filter
    components are missing, damaged or not genuine Hayward components."
    18x32 kidney 15K gal IG Gunite pool; skimmer tabs; Hayward DE6000 DE filter; Hayward/AO Smith Superflow 1 speed pump; 12 hrs; heat pump, fountain or waterfall; Taylor K2006C ; utility water; summer: none; winter: none; android tablet; PF:8
    May 2012
    Phoenix, AZ
    Thanks Ben.
    I had attached the picture with my previous reply(but for some reason, it looks as though you were not able to see it). And the manual you mentioned is the one that I referred to when taking apart the filter grid and putting back together. From the picture you posted, it is similar except that the pressure gauge is sort of protruding on top and the top lid is a bit more taller in my filter. Let me try to attach the picture again.
    I *think* those are the same filters, but I'd suggest doing this:
    1. Call Hayward support: 866-429-7665 for Arizona (I tried, I can't call that #)
    2. Write down (or print, or have an email ready with) the link for this thread:
    www.poolforum.com/pf2/showthread.php?15837
    3. Ask the Hayward rep to LOOK at the picture in this link, and see what model it is.
    May 2012
    Phoenix, AZ
    Thanks for the number Ben!
    I called at the number and spoke to a tech support. He told me that my unit is a DE6000.
    Were you able to find the matching manual?
