Results 11 to 12 of 12
Thread: Are we doing it right?
    May 2012
    Texas
    Default Re: Are we doing it right?
    Okay, it's the wife here (the one maintaining the pool). Now, our CC is too high. We only lost 4PPM of chlorine all day today, so I think we're making progress. But, now I am concerned about the CC being too high. I've read that it says to shock it to get rid of the CC, but how much? I am already at 17PPM FC.
    FC: 17
    CC: 1.5
    CYA: 100
    PH: 7.4
    In ground w/attached Spa - Pebble-Tec, chlorine, 17,000 gallon, Sand Filter Pentair TA-100D, Whisper-Flo filter pump WF-28 2HP
    Losing 4 ppm of chlorine during the day is not an indication of a problem . . . especially if you had some swimmers. 1.5 ppm CC might, or might not, be a problem.
    Please use this form I created for you, to record your complete pool info (including water condition, filter pressures and calcium levels): PF Pool History - TTorreyson
    You can see the results, here: PF Pool History => TTorreyson
