Results 1 to 10 of 80
Thread: Cannot Get Rid of Cloudy Water
    ajb8898 is offline Subscriber Thread Analyst ajb8898 0
    May 2012
    South Carolina
    Default Re: Cannot Get Rid of Cloudy Water
    I came home from vacation the pool is clear!!! Woo Hoo!!
    FC: 10
    TC: 10
    pH: 7.6
    TA: 150
    CYA: 60
    Can't thank you guys enough for your help and sticking with me through all this. I've learned so much about our pool and have really taken ownership of it through this. I'll be sharing the BBB method and this board with as many pool owners as I can. I'm sure I'll be back on when other problems come up.
    15K gal AG oval w/ Hayward sand filter; Taylor K2006C
    15'x30' oval 15K gal AG pool; bleach; Hayward sand filter; Hayward pump; 24hrs; Taylor K2006C; utility water; summer: ; winter: ; iPhone; PF:8
    Lehigh Valley, PA
    Excellent!
    Don't use anymore dichlor powder or trichlor pucks. Your CYA is at a good level and you don't want it any higher. Switch to plain bleach now.
    Your TA is high. It should be between 80 and 120 in a vinyl pool. Do you have a lot of splash-out that requires frequent refilling? If so, that'll dilute the TA on its own. Have you ever tested your fill water?
    May 2012
    South Carolina
    I do refill when we have a lot of use out of the pool or it's really hot. I tested our tap water and it was low...like 40 or 50. Do I need to add anything to bring that down?
    Actually, for a vinyl pool, I wouldn't worry about adjusting your alk. You're just a little high and I don't think it will cause you any problems if you just leave it where it is. Plus, if your fill water has low alk, then as you add water, it will gradually bring it down.
    Hope you enjoyed your vacation!
