I crawled under there and was surprised to find its a 1HP unit. The model on the motor and pump is SP2175X10CSA, the motor rating is listed at 1HP and 11.6A.
While the size of the pump is oversized for the sand filter, is it appropriate for the size of the pool, ie. I should change out the filter OR is it too large for my application and I should downsize the pump. To be honest its not sounding that great ( I work for a residential pumps and water treatment company here ) and I'm sure its bearings are about done so if I had to replace it with a smaller model it wouldn't be a surprise. If I have to upsize the sand filter, the cartridge for the whole pool may be good.
Now that I'm starting down the path I can already see that by nature the operating requirements of the sand filter will not aide my overall well supply situation. If I can move to a decent cartridge filter for the whole pool and avoid the water loss associated with a backwash/rinse etc of the sand filter that may be the smarter move.
Thanks for the thread and the help. I know about the water chemistry but the pool flow requirements are all foreign to me and I'm trying to adapt. I'm used to 10gpm and 5um filter talk.
