Yep 2lb - but what I meant was about/around 2lb. You don't need a scale. Measure - treat - measure - treat ... is the process we promote here. Put in less than you think you need at a time, wait for it to mix, test and re-dose. Try to approach your treatment goals slowly to avoid going over. Calculating and dosing all at once sets us up to see-saw and chase numbers which is not as much fun as swimming.
Is the pH up you have Sodium Carbonate? Add about a pound (instead of 2lb Borax) at first. It will also raise your TA.
Your cl feeder is on and has trichlor pucks in it?
