Results 1 to 10 of 14
Thread: New Pool
    Default Re: New Pool
    Until your registration is completed, you will have to log out first and then you can see and follow the links.
    Registration updated - PoolDoc.
    May 2012
    South Carolina
    Ok, I got the K-2006 test kit today. After much frowning and testing I got the following results.
    Chlorine 10ppm
    pH needed 2 drops of R-0006 to be 7.4
    Alk 90ppm
    Calcium 220ppm
    Cyanuric Acid <30 filled small test compartment and could still see black dot (barely)
    Table D is 10.3oz (Sodium Carbonate) for 10,000 gal pool. I have about 13,500 gal pool. So I need a scale now??
    BigDave's Avatar
    Congrats! The k-2006 will help you control your pool and maintain your liberty.
    For now, put away the acid and base demand tests and the book and the wheel. And don't frown
    What was your pH reading?
    How have you been chlorinating?
    How does the pool look?
    Another half box of Borax poured slowly in the skimmer will help raise your pH.
    May 2012
    South Carolina
    Hi Dave,
    The pH was just barely 7, and I have not added any chlorine although I have an inline auto feeder. The water is crystal clear.
    I have some pH up from Walmart but it has been raining steady for 3 days (added 1/2" to pool level) so haven't made any adjustments or readings since it started.
    By half box of Borax you mean 2lbs?
    thanks for you help
    BigDave's Avatar
    Yep 2lb - but what I meant was about/around 2lb. You don't need a scale. Measure - treat - measure - treat ... is the process we promote here. Put in less than you think you need at a time, wait for it to mix, test and re-dose. Try to approach your treatment goals slowly to avoid going over. Calculating and dosing all at once sets us up to see-saw and chase numbers which is not as much fun as swimming.
    Is the pH up you have Sodium Carbonate? Add about a pound (instead of 2lb Borax) at first. It will also raise your TA.
    Your cl feeder is on and has trichlor pucks in it?
    May 2012
    South Carolina
    I added about 1lb of Sodium Carbonate (pH up) yesterday. Then it rained a ton.
    The feeder is NOT on, and the tablets (3" trichloro-s-triazinetrione tablets) are still in the car, lol.
    Chlorine dropped to 6ppm.
    pH is 7.6 now after adding and waiting approx. 24hrs to retest.
    I have no Combined Chlorine reading still. Is that a problem?
    looking good i think.
