Results 1 to 9 of 9
Thread: Whats the difference between in ground and above ground sand filters ?
    May 2012
    South Carolina
    Question Whats the difference between in ground and above ground sand filters ?
    A friend gave us a Tagelus TD-40 filter that was on an inground pool. Is it ok to use this for an above ground pool?
    18' round 7.7K gal AG vinyl pool; Bleach; Hayward S144T sand filter; Hayward 1HP pump; hrs; Taylor K-2006; City; summer: ; winter: ; ; PF:16
    May 2012
    South Carolina
    Default Re: Whats the difference between in ground and above ground sand filters ?
    I guess I'm not the only one that doesn't know.
    Sherrie;
    We've just been slammed. Traffic has been up since Christmas, but over the last 2 weeks, traffic has been DOUBLE what it was this time last year. We're not keeping up, but all we can do is hang on till June 15 when it begins to slack a bit.
    You can use an IG filter on an AG pool; Watermom and a number of more experienced PF users do so. IG equipment tends to be a bit more durable and better designed, than AG gear, and the application ratings are closer to being realistic.
    What may have caused hesitation in answer your question is that these questions tend to be followed by, "How do I connect it?" and it's hard to answer those sorts of questions over the internet.
    May 2012
    South Carolina
    Okay we're gonna try it this weekend. My pool looks pretty and blue but it's still not crystal clear. I figured it would be better because it's much bigger. Thanks
    Quote Originally Posted by sherriemoseley View Post
    This statement isn't right. You can buy above ground filters and inground filters that are the same size.
    BigDave's Avatar
    The Tagelus TA 40D isn't very big but Hayward's site has been down all day so I can't compare the S144T. I you think it's bigger, maybe worth it. Can you rig them both in parallel?
    Above ground / in ground I see no difference except marketing.
  1. Difference between AG and IG filters?
    By sunlove in forum Pool Equipment & Operations
    Last Post: 05-15-2012, 01:42 AM
  2. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  3. Difference in DE filters?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 05-12-2007, 12:35 AM
