Results 1 to 9 of 9
Thread: Whats the difference between in ground and above ground sand filters ?
    BigDave's Avatar
    Default Re: Whats the difference between in ground and above ground sand filters ?
    Well then, your path is clear. I wouldn't bother to plumb in the 50lb filter. Still, watch out for losing sand on backwash 1hp pump is pretty big.
    Jun 2011
    In the Sticks near Houston, TX
    I have a tagelus 60D for a 1- HP pump. I like it fine. I thought I had a filter problem but it ended up being several other things.
    Just make sure you are very, very easy when plumbing in the valve head. I ended up cracking both the inlet and outlet despite trying not to. They leak a little bit.
    I would suggest only going hand tight and that's it. I went hand tight plus 1/4 turn with a wrench. Ended up that hand tite probably would have been best.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
  1. Difference between AG and IG filters?
    By sunlove in forum Pool Equipment & Operations
    Last Post: 05-15-2012, 01:42 AM
  2. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  3. Difference in DE filters?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 05-12-2007, 12:35 AM
