Thread: wall return fitting
    duraleigh Guest
    Default Re: wall return fitting
    Hi, Beth,
    Most standard wall returns are 1.5". You probably have these on your pool despite that there is 2" leading to it.
    If 2" really is your return fitting, it's easy to find the appropriate reducer at HD/Lowes to adapt to your wall fountain.
    Thanks Dave,
    I will get my fountain and check it out on monday... thought it should be pretty standard. Thanks for the reply.
