Results 1 to 10 of 11
Thread: 27,000 gallon green swamp HELP
    May 2012
    columbus ohio
    Default Re: 27,000 gallon green swamp HELP
    The pool pump is a Dynamo the sand filter is a intex and the shock granules were called shock xtra by utekem
    Last first: "were called" -- are the granules gone, or do you still have some?
    You have an Dynamo pump and an Intex sand filter on a 27,000 gallon pool? That doesn't sound right. What are the dimensions of your pool?
    Have you added bleach? Do you have an OTO kit? Did the pool hold chlorine overnight?
    May 2012
    columbus ohio
    The pool is 27' round the pump is a 1-1half pump ,150lbs capacity filter system.
    The pool water is still green. We have been vaccuming it out . Had a lot of leaves
    On the bottom. Dont have any more chemicals . So do I add more bleach now
    That I have it vaccumed out .
    May 2012
    columbus ohio
    What type of numbers. I just put the pool size and filter. What does CYA mean .getting very frustrated all ready .
    Ms Dean;
    Proper pool management has a learning curve -- and you are currently at the steep end of that curve. We can help, but we can't change the reality. In the US pool market you have 3 choices:
    1. You can be a victim of pool store tactics, as you have been in the past.
    2. You can learn to manage your pool chemistry yourself -- and we can help with that, but YOU still have to learn.
    3. If you are very, very lucky, you can find a really good local pool store to help you. We estimate about 2% of pool stores fall into this category.
    The choice is yours. But we can only help with option 2.
    However, if you select option 2, I can tell you that you are going to need to obtain an essential pool tool, that has been in short supply, as long as I've been doing the PoolForum: P.O.P.* Without it, your efforts will fail, and you will waste your time and ours.
    Best wishes with your decision.
    * P.O.P. = Pool Owner Patience
    May 2012
    columbus ohio
    I am willing to learn to manage my pool. I think the problem was i didnt winterize the pool. Just tellme if I need to add more bleach
