Thread: Aiming the eyeball
    May 2010
    Illinois
    Default Aiming the eyeball
    Ok, so I've got a rectangular in-ground pool. approx 13.5' x 24'. The shallow end is 3' deep and the deep end is 5' deep. There's not only a slope from the shallow to deep end, but a slope from the deep end walls@ 3' to the center of the deep and at 5'. Hard to describe… The skimmer & return are on the same 13.5' wall.
    I'm trying to figure our where best to aim the eyeball so that cr*p stops missing the filter. I know I get full circulation, but dirt seems to get suspended in the water, and just goes around & around. It never comes to the top, so it never gets sucked into the skimmer. I've been out there w/ my net, which isn't so bad, but I do have other things to do w/ my time (unfortunately).
    Any ideas?
    Rob
    Lehigh Valley, PA
    Default Re: Aiming the eyeball
    Have you heard of the PoolSkim? Here's a link to ours: http://ellerbach.com/Pool/PoolSkim/ . It is attached to the return and does an amazing job catching floating debris. If you have just the one return and need it to hook up a cleaner it could be a bit of a hassle to put it on and take it off. I never looked for a quick connect system because we don't need the one return we have.
    Before we bought the PoolSkim and used the eyeball we aimed it slightly below the water surface and away from the skimmer, but ours is an oval pool, different circulation.
    May 2010
    Illinois
    Thanks Anna, but that's not really what I'm after.
    Rob
  1. Return eyeball has a funnel
    By Bonnie25 in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 09:01 PM
  2. Natural Chemistry products aiming at reducing phosphates. Should I use it?
    By cdysthe in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2012, 10:08 PM
  3. Replacing eyeball returns
    By schristi69 in forum Pool Equipment & Operations
    Last Post: 06-14-2011, 11:46 PM
  4. Eyeball direction?
    By abessellieu in forum Pool Equipment & Operations
    Last Post: 08-13-2006, 01:54 PM
  5. Eyeball looks where?
    By bsbrega in forum Above-Ground Pool Construction & Repair
    Last Post: 05-20-2006, 09:15 AM
