Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
Thread: green water
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    Default Re: green water
    ok, before I multiply it's not quite at 50 so about 52which makes it 104 after I mult by 2
    I know that's high....
    OK.
    It will be sort of expensive, but if get the pool cleaned up is the priority do this:
    1. Buy whichever granular product cleared the stains fastest and was cheapest. (Your chlorine is going to break them down anyhow!)
    2. Apply it as best you can, directly to the stains. One possible way would be to take a 2 gallon freezer bag, put 1/2 pound of stain remover in it, add 2 cups of water, and then a medium wash cloth. Saturate the wash cloth in the concentrated slurry, and then close the bag, after forcing the air out. Get into the pool with the bag, and open it NEXT to a stained area, and wipe the area down. That way, you may be able to use the bag to avoid a lot of the mixing and dilution with pool water that would otherwise occur. You probably want to wear gloves to avoid concentrated exposure to the acid.
    3. As before, make sure your pump and filter are working well. What will happens is that the metal + the citric or ascorbic acid will go into the pool water, and encounter the chlorine. This will break down the organic acid, releasing the metal -- which will hopefully then end up on the filter BEFORE it can stain the pool again.
    4. Don't let folks submerge their heads or get their eyes in this water for 24 hours afterwards, if you use citric acid. It initially forms some irritating products with chlorine.
    5. Don't worry about your chlorine level, till it gets near 7 or 8. At that point, you'll need to begin adding chlorine again. Do brush any areas of algae BEFORE starting all this.
    May 2010
    New York
    should I worry about my cya or ph etc, yet?
    cant get in the pool to to do this because the staining is at the bottom of the deep end, so ill just try to throw it in there better i guess..or buy vit c tabs and throw those
    thanks again for helping!
    Ill keep you posted
    Quote Originally Posted by mrszaff View Post
    Sams Club has some great big bottles of Vit. C tabs that are pretty inexpensive. Tabs wouldn't dissolve as quickly as the granular, so that might work. I'd be interested to know if it does -- other people might want to try it.
    May 2010
    New York
    It's working, thanks!
  6. #16
    May 2010
    New York
    OK, the pool looks great and we were able to use it this weekend.I just took a reading and my chlorine is zero! So I want to add bleach without turnng the liner brown again from a metal reaction. How much should I add at a time? what #am I loking to reach?
    here are my other numbers: Ph 7 Alk 20 cya 90
  7. #17
    Add 1/2 gallon at a time -- on your pool that will be about 1.5 ppm. If you have 0.0 chlorine, and CYA = 90, try to get at least (3) 1/2 gallon doses in tonight. Add them via the skimmer, and wait 30 minutes between doses.
    By the way, if / when you add acid to the pool, do NOT add it via the skimmer! Doing so will take metals OFF the filter and put them BACK into the pool!
  8. #18
    May 2010
    New York
    I added 2 gallons of 6percent bleach , should I add baking soda?
    we had a lot of rain the past few days and it got cold the pool is now cloudy and turning green but I want to avoid metal...
    also, I haven't added and borax or baking soda yet
    fc 3.2
    cc .5,
    ph 7.1
    alk 30
    cya 100
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
  9. #19
    You need to add Borax and you can also add baking soda.
    Remember, when it rains, your pool still needs chlorine. We see this many times each season where somebody posts that it was rainy and the pool turned green. Rain does not turn pools green. Rather, people don't check on their pools when it rains and then chlorine gets low and algae gets started.
  10. #20
    May 2010
    New York
    how much baking soda and borax?
