Re: Ultraviolet pool sanitizers
UV is a supplemental system only and does not replace chlorine. It has some use in commercial/public pools where either UV or ozone is used to help kill the protozoan oocyst Cryptosporidium parvum which is very chlorine resistant, but that's not needed in a residential pool where you aren't swimming with strangers that have diarrhea and where one person could infect hundreds. UV is also useful in an indoor pool to help control chloramines since there is no UV from sunlight to do so.
However, in an outdoor residential pool, there isn't normally a need for either UV or ozone because the bather load is low in a residential pool so chlorine is able to do the job just fine by itself, especially with the UV in sunlight helping out.
