Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 42
Thread: Possible pump motor bearing failure?
    May 2012
    United States
    Default Re: Possible pump motor bearing failure?
    done. no change
    May 2012
    United States
    Default Re: Intro Post and Problem...
    Steps so far the recap:
    Removed ozone line and plugged with OEM plug per suggestion.
    Impeller, seal, wear ring, replaced, though clearly unneeded (i already ordered before talking to the experienced folks on here)
    The basket side has no visible cracks, etc.
    removed motor from pump and it is quiet as a mouse when left running without a load
    The main symptom is in a matter of seconds it starts making the racket like cavitation and the pressure drops at the filter.
    On the suction side is two skimmers and a double drain.
    On the pressure side is filer, chlorine feeder, split off to a return valve and a water feature valve.
    The last things done prior to this occurring though this did not start when these maintenance items were performed
    Filters pulled and cleaned
    Valve to water feature replaced
    Thanks All. At some point I guess i will be calling service, the fam will only wait do long on my shenanigans....
    May 2012
    United States
    Ran the pump again, it full primes and still making that racket and not creating pressure
    If it is air, going after the last 3 parts that could be doing it out of sight between the basket and impeller...
    Diffuser
    Diffuser O-ring
    O-ring between the two main halves.
    go ahead and get a new one for the basket lid too
    After that... may be time for a service call
    mas985's Avatar
    Pleasanton, CA
    Some things are harder to troubleshoot than others especially in a forum but it is still good to eliminate causes. One thing I cannot tell from the video, it moves around too fast, is what is happening in the pump basket when the noise begins and the filter pressure drops. Is there any change and do you see any air entering the pump basket? All the symptoms and sounds point to an air leak and I just want to make sure that I am not missing anything. Just for kicks, check the skimmer weir door and make sure it swings freely.
    Mark
    May 2012
    United States
    Default
    Full Prime, no air in basket. If there is air it is somewhere between basket and impeller, unseen.
    Skimmer is full of water when this is occurring.
    door swings and plenty of water flowing
    Would the diffuser O ring cause this issue? How about the diffuser itself?
    The o ring between the two halves (exterior that the 6 bolts snug up), am I correct in that, that is pressure side and if an issue that would leak water...
    Additional note: Shaving creme
    Foamed up all the joints from the valves to the union, basket lid, and the two plugs... no signs of air being pulled through exterior suction side joints or gakets.
    Basket side remains clear of bubbles...
    It sounds like maybe the diffuser O ring is not letting the pump fully pressurize and causing the chattering? Or shooting blanks...
  6. #16
    mas985's Avatar
    Pleasanton, CA
    I doubt it unless the diffuser was spinning inside the housing but you would have seen signs of that with the old diffuser.
    Yes, any leaks on the pressure side would be squirting water.
    Originally, you had posted this:
    It is a hayward tristar and I noticed the white impeller ring (looks like a white bearing race) has numerous etchings as well as the neck of the impeller that it slides over....)
    If the the impeller ring is not seated well or the wet end is damaged in some way, it may be possible that there is a periodic loss in pressure due to recirculation losses but this is just speculation at this point.
    How badly damaged were the impeller ring and impeller and did you inspect the wet end housing for any cracks?
    Also, is the filter filling up with air and do you see any air coming out of the pool returns?
    Mark
  7. #17
    May 2012
    United States
    The impeller wear ring was slightly etched in comparison to the new. after seeing the new, that was probably normal wear. The impeller itself had no damage and kept it as a backup.
    Diffuser was not replaced. It also would never be allowed to spin as the tristar has two screws holding it in place
    Occasional bubbles at the returns, some air can be let off from the filter (though not seen in the basket).
    Looked all on the strainer (suction) side and can spot no cracks..
  8. #18
    Sounds like you may need to exorcise the pump pixie!
  9. #19
    May 2012
    United States
    It has crossed my mind to have the top two feet jackhammered, back filled, and go back to mowing a lawn....
  10. #20
    mas985's Avatar
    Pleasanton, CA
    Ok, I am starting to run out of ideas but I am not willing to give up yet. If you have a suction gauge, it might be helpful to find out what is happening on the suction side of the pump during this period of pressure drop. If the suction increases during this period, it could be cavitation that we are hearing and then we just need to figure out what is causing the suction to increase. If the suction decreases, it could mean that there is something occurring inside the pump besides cavitation. Most gauges with 1/4" fitting will fit the suction side drain plug.
    If you want to give up, I completely understand. These types of problems can be very frustrating.
    Mark
  1. Pump Failure Survey
    By mas985 in forum Pool Equipment & Operations
    Last Post: 02-04-2015, 12:33 AM
  2. Replace motor or pump and motor?
    By myLABSpool in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 02:13 PM
  3. Replace motor or motor& pump?
    By jtcaputo in forum Pool Equipment & Operations
    Last Post: 09-08-2012, 08:27 PM
  4. Bearing Replacement 1hp AO Smith Motor
    By Spurgeon in forum Pool Equipment & Operations
    Last Post: 05-15-2010, 02:18 AM
