Results 1 to 10 of 42
Thread: Possible pump motor bearing failure?
    May 2012
    United States
    Default Re: Intro Post and Problem...
    Low speed seems to operate at as much pressure as high after it freaks out. So after high takes its split second nose dive from 19 to around 4 or 5... I simply kick it to low... the noise stops (which seems to come from the impeller area) and low speed is quiet like it should be. Once it is done running for the day I will let it sit... High seems fin on a cold start...
    Kick it on and video what it is doing... a picture is worth a thousand words but youtube is priceless.....
    May 2012
    United States
    http://youtu.be/6zskny8Osfo
    So at the beginning is normal pressure, never loses prime. I can close the return valve which will force pressure to go back up, but once the motor gets in this state it continues to run visibly rough.
    At this point the motor seal, impeller and wear ring have been replaced... no change I suspect something internal to the motor itself.
    I don't know -- sound quality in the video is not good, and is very hard to listen to, but if the blue tubing in the screen cap below is passing air into the volute (chamber behind the pump strainer pot chamber) you'd get just that sort of effect. And, it's very, very common for tubing connected to pumps via the drain ports to cause that sort of problem:
    May 2012
    United States
    That tubes job has been to pass air, its from the ozone generator and has passed some "air" since install 3 years ago.. But it is turned off while chasing this problem
    And for the unit to run fine for the first 15-20 minutes repeatedly seems improbable to be related to the basket (suction) side. But that 15-20 minutes does have to occur after overnight cold.
    mas985's Avatar
    Pleasanton, CA
    It doesn't mater if the ozone line is off, you need to remove the line and put back the drain plug otherwise, you can't eliminate that as the cause. It definitely sounds like air is getting into the pump and if it is injected at the bottom, you may not see it in the pump basket.
    Mark
    May 2012
    United States
    Default Re: Possible pump motor bearing failure?
    done. no change
    May 2012
    United States
    Steps so far the recap:
    Removed ozone line and plugged with OEM plug per suggestion.
    Impeller, seal, wear ring, replaced, though clearly unneeded (i already ordered before talking to the experienced folks on here)
    The basket side has no visible cracks, etc.
    removed motor from pump and it is quiet as a mouse when left running without a load
    The main symptom is in a matter of seconds it starts making the racket like cavitation and the pressure drops at the filter.
    On the suction side is two skimmers and a double drain.
    On the pressure side is filer, chlorine feeder, split off to a return valve and a water feature valve.
    The last things done prior to this occurring though this did not start when these maintenance items were performed
    Filters pulled and cleaned
    Valve to water feature replaced
    Thanks All. At some point I guess i will be calling service, the fam will only wait do long on my shenanigans....
    May 2012
    United States
    Ran the pump again, it full primes and still making that racket and not creating pressure
    If it is air, going after the last 3 parts that could be doing it out of sight between the basket and impeller...
    Diffuser
    Diffuser O-ring
    O-ring between the two main halves.
    go ahead and get a new one for the basket lid too
    After that... may be time for a service call
    mas985's Avatar
    Pleasanton, CA
    Some things are harder to troubleshoot than others especially in a forum but it is still good to eliminate causes. One thing I cannot tell from the video, it moves around too fast, is what is happening in the pump basket when the noise begins and the filter pressure drops. Is there any change and do you see any air entering the pump basket? All the symptoms and sounds point to an air leak and I just want to make sure that I am not missing anything. Just for kicks, check the skimmer weir door and make sure it swings freely.
    Mark
