Re: Taylor Fas-DpD Test Kit K-2006
just an update to my readings only a couple hours later
FC .4
CC .4
PH 7.0-7.1
TA 111
CH 245-250 ppm
CYA ...still does not register(solution stays pretty clear)
Maybe I should have provided some more details that may help, this pool was the worst I've seen it this year upon opening because I did very little to close it last year due to some health issues. When I first removed the cover you could see the bottom, but there was visible algae and a dead squirrell that got under the cover. In just a matter of a couple days it turned dark green with all the heat in N.E. Ohio, during which time I was searching for a replacement pump motor because mine was locked up tight. Since then I have had multiple trips to the pool store and been sold mutard algae killers, phosphate removers and tons of shock. Dont get me wrong there has been improvement to the poool since the start but not like I would have thought considering all of this. ( Sorry about being windy
20x40 IG vinyl liner; 300lb sand filter with a 1 HP pump
