Thread: Start up super chlorination?
    May 2011
    Default Start up super chlorination?
    Good day. I'm back at it, starting the pool up again. This is only my second year with a pool, so lots of basic questions. Right now, I'm concerned with getting the pool going. I've been running the filter 24 hours a day are will do so for the first week. I've added the correct amount of salt and it's dispersed well. Now, I've got the SWCG running. What is the maximum amount of time that I should leave the SWCG at 100%?
    BigDave's Avatar
    Default Re: Start up super chlorination?
    Is the water clear? What's your FC, CC, CYA, pH, TA? What type of pool, filter? Size of pool, filter and pump? This information will help you get answers you seek.
    May 2011
    Because I just opened the pool on Monday, I haven't tested the water yet. Right now, the water just looks dirty. A little greenish hue with some dirt at the bottom making it a little foggy. I guess my question is really could leaving the SWCG at 100% for a few days straight cause damage to the cell?
    Below are the specs:
    16' x 36' IG - ~22K gallons
    Vinyl liner (2010)
    Filter: Pentair Clean and Clear Plus CCP420 420 Sq Ft (2008)
    Pump: 1.5 hp Hayward Super Pump
    Heater: Sta-Rite Max-e-therm
    Chlorinator: Aqua Collection Turbo Cell
    My understanding is that it can substantially reduce the cell life. We recommend that folks turn off the SWCG until the water is balanced, using bleach, dichlor, or cal-hypo for chlorination (depending on your pool's needs), and then using the SWCG for normal chlorination after the chemistry is right.
    Virginia
    The owners manual for my SWCG (Aquarite) states the pool must be balanced before starting the SWCG. I use to use the "superchlorinate" feature (runs at 100%) to shock the pool, but when my first cell died after 4 seasons and I learned how much replacement cells are (ouch!), I decided to only use the SWCG to maintain chlorine levels. Since getting a new cell, I shock with cal hypo and turn the SWCG off when doing so. I expect this will extend the life of the cell.
    May 2011
    Thanks for the advice. I should have posted here before I kept the superchlorinate on for the better part of a day. It makes sense to shock and balance the pool before running the SWCG. Thanks again!
    16x36 IG 22K Vinyl | Pentair Clean and Clear Plus 420 Sq Ft | 1.5 hp Hayward Superpump | Aqua Collection Turbo Cell
    BigDave's Avatar
    Remember - you need that CYA number so you can know what your chlorine targets are.
  1. Super-simple recipe for Intex type swimming pools
    By PoolDoc in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-07-2018, 09:22 AM
  2. (New User) Hayward 1 HP Super Pump no start
    By donjjr in forum Pool Equipment & Operations
    Last Post: 08-15-2011, 11:37 PM
  3. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  4. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  5. Hayward Super Pump - no start with loud buzz
    By hhkont in forum Pool Equipment & Operations
    Last Post: 08-14-2010, 10:46 PM
