Thread: Start up super chlorination?
    Default Re: Start up super chlorination?
    My understanding is that it can substantially reduce the cell life. We recommend that folks turn off the SWCG until the water is balanced, using bleach, dichlor, or cal-hypo for chlorination (depending on your pool's needs), and then using the SWCG for normal chlorination after the chemistry is right.
    Virginia
    The owners manual for my SWCG (Aquarite) states the pool must be balanced before starting the SWCG. I use to use the "superchlorinate" feature (runs at 100%) to shock the pool, but when my first cell died after 4 seasons and I learned how much replacement cells are (ouch!), I decided to only use the SWCG to maintain chlorine levels. Since getting a new cell, I shock with cal hypo and turn the SWCG off when doing so. I expect this will extend the life of the cell.
    May 2011
    Thanks for the advice. I should have posted here before I kept the superchlorinate on for the better part of a day. It makes sense to shock and balance the pool before running the SWCG. Thanks again!
    16x36 IG 22K Vinyl | Pentair Clean and Clear Plus 420 Sq Ft | 1.5 hp Hayward Superpump | Aqua Collection Turbo Cell
    BigDave's Avatar
    Remember - you need that CYA number so you can know what your chlorine targets are.
