Thread: stabilizer question
    Apr 2012
    Panama City Beach, Fl
    Default stabilizer question
    What is the difference between isocyanuric acid and cyanuric acid. Is there one to prefer over the other? I will be running an Aqurite SWCG and it is recommending a CYA of 80ppm. Would I want the same pom if using isocyanuric acid? Thanks
    In Ground, 6,900 Gallon Gunite pool with tile trim, Haywayd EcoStar SP34000VSP Variable Speed, Aquarite 25k SWCG, North Florida
    Default Re: stabilizer question
    I'm not a chemist, so there may be chemical differences in the two, but for non-chemists who just want CYA in the pool, for all practical purposes, it's the same stuff!
  1. stabilizer
    By unklebuk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-03-2012, 04:51 PM
  2. When should i add stabilizer?
    By thumpzilla in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2012, 10:58 PM
  3. Stabilizer question
    By scsteven in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-24-2007, 09:55 AM
  4. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
  5. Open new pool - question about adding stabilizer
    By The Raddish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2006, 12:49 PM
