Results 1 to 10 of 36
Thread: Low chlorine reading
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default Re: Low chlorine reading
    Yes, I bought a nice brush today and vigorously brushed the side walls. I then vacuumed the pool as best I could and ran it to waste instead of filter.
    I have read many other threads here regarding algae problems, and am confused. Your recommendation is to only add 4-54 gallons of bleach tonight and re-test in the morning....if gone add 2 gallons right away in the AM? Repeat this process until chlorine holds all night??
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    If your pool is green -- you have an algae problem.
    If your pool is cloudy white and doesn't not turn green when you brush, and you can't hold chlorine overnight . . . you have a DIFFERENT problem.
    Either way, getting chlorine to hold overnight is a key first step. But, I want to avoid massive doses that might temporarily be high enough to bleach your liner. So, until you have a good kit and have given us test results, I'd recommend sticking with the doses I suggested.
    May 2012
    Buffalo, NY
    OK, so I got a test kit today and did my own tests, here are the results:
    ph 7.8 (I added acid today to lower)
    FC .6
    CC 1.0
    TA 210
    After reading numerous posts on this board, I suspect my cloudy water problem stems from high TA and the soda ash that I added because pool store #1 told me my ph was low, even though my test strips told me it was OK. I also understand that TA is diufficult to lower. Pool store #2 suggested removing some water and replacing....then repeat again.
    After scrubbing the sides and floor of the pool, it still stays a milky white color, and I can only see about 12-18 inches down. Earlier in the week prior to adding soda ash, I could see the bottom of the shallow end but not the deep end. I just discovered after reading here that soda ash also raises alkalinity, so I created my own problem it seems.
    How do I proceed from here??? Should I remove water, add water and shock with bleach? That is the way I am leaning now. Thanks in advance for any help!!!!
    1. Get a kit that measures calcium hardness and stabilizer! Tell us what you have.
    2. Use muriatic acid (read the page linked in my signature!!) and lower the pH, a little at a time, to just above 7.0 . . . and KEEP it there. It will keep trying to rise.
    May 2012
    Buffalo, NY
    I forgot to add those.
    Calcium hardness 250
    CA 30
    I am getting a better tester kit because I can see that I can trust my numbers more than the pool stores.
    By the way, store #2 called back and suggested hitting my pool with 19 gallons of chlorine to super chlorinate but I am going to go with 6 gallons as suggested here and retest in the morning
    May 2012
    Buffalo, NY
    CA 30
    Hardness 250
    ph 7.8
    FC 0
    TA 210
    So after sundown at around 8 PM, I added 7 gallons of regular bleach. I tested after about 15 minutes and ph was WAY high but I figured it was a false read due to the bleach I just added. The FC was off the charts, my test strips went dark purple and my OTO was VERY yellow. I figured I was good for the night.
    So now it's 11:40 PM and I figured I would re-test. FC is now VERY low, .6, and ph was back to 7.8. That tells me something is using up my chlorine at a CRAZY level. It went from somewhere over 10 ppm to almost nothing in a few hours. Now I think I am gonna have to go over the top with the bleach to kill whatever (amonia, bacteria or algae) is living in my pool.
    Any thoughts here?
    Quote Originally Posted by sabres07 View Post
    Any thoughts here?
    Not so much. What you're experiencing is pretty much standard for folks with ammonia from CYA in their pool.
    Don't let yourself get impatient and
    -- you'll end up with real problems. Instead, simply hang in there with repeated moderate chlorine doses. If you like, you can close up the interval on the doses, doing one at 7pm and another at 11pm. But test with OTO before you dose. If you don't test, you'll suddenly end up with extremely high chlorine levels, and with no CYA in the pool you're liable to end up with a bleached liner.
    May 2012
    Buffalo, NY
    OK, I will stay the course. I do have a 30 for CYA. Does that change your opinion on what I should do?
    Thanks for all of your help so far.
