Hello. I have a 24 ft above ground pool. I cleaned up REALLY nasty water (think algae, tadpoles, leaves, and stinky) last year and I am working on my second opening with the same problem except for twice as much algae because of the warm winter but no tadpoles. I am seeing progress but it is so slow (almost a week now using the BBB method). I got the pool in 2010 and have never replaced the sand and I was wondering if I could speed things up by changing out my sand. It has been used for its second disgusting opening and two summers of normal filtration.
I was also wondering if I do replace is it ok to used silica sand used for water treatment? I know there are different grades but I have looked and looked and I can't really find a lot of information. This sand is leftover and would be free for me.
I also have the noisy pump problem......it is horrible. I want to replace. It works fine....water circulation is good....it just is impossible to talk over or around. I am going to get some info to post. Thanks for your help.
