Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: Help interpreting FAS-DPD FC/CC test results **Sorry, long, techy post**
  1. #21
    BigDave's Avatar
    Default Re: Help interpreting FAS-DPD FC/CC test results **Sorry, long, techy post**
    The CC is a byproduct of the FC oxidizing the (presumptively) ammonia in your pool. It's always an indication that there's something in the pool that's being oxidized by the chlorine.
    The goal of shocking is to get rid of stuff in your water that doesn't belong there. When you can hold (less than 1 ppm loss) FC overnight (no loss to sunlight) and measure nearly no (0.5ppm or less) CC for two nights in a row, you'll have have finished shocking (gotten rid of unwanted pool stuff).
  2. #22
    Hi All;
    I've seen some things that make me suspect that, with the DPD-FAS test, you will see a CC residual, when the FC gets high enough, even though there may be no actual CC's present. It's something that needs to be tested, first with distilled water at FC=50 ppm and then with distilled water + 20 ppm CYA at 50 ppm FC.
  1. Newbie needs advice interpreting first test results
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2010, 11:30 PM
  2. Test results post fiasco
    By kathgilliam in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2006, 01:54 AM
  3. Test kits - interpreting the numbers
    By kbcpa in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2006, 09:45 AM
  4. How long to get Borax PH increase test results?
    By famdog in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 02:50 PM
  5. ps234 test results - first post
    By charlie75 in forum DPD-FAS based testing
    Last Post: 05-31-2006, 10:11 PM
