Results 1 to 10 of 17
Thread: Super low pH (and other problems)
    May 2012
    Pennsylvania
    Default Super low pH (and other problems)
    Hello,
    I've been working on getting my just opened 30,000 gal pool to go from black to blue (current status - blue green and cloudy).
    My pH is reading REALLY low. It doesn't even put any color on my multi-test pool strips (which start at 6.8).
    I have two sets of homebrewing strips I tried out in the pool - 0-14 & 4.8-5.8. The 0-14 strips put the pH roughly in between 4 & 6, and it looks like the 4.8-5.8 strips are reading 5.0. (These strips are a few years old - what's their shelf life?)
    So, after reading this site, I dumped in two boxes of borax and got no reading this morning (mutli-test 6.8 min only, I was in a hurry) on the pH again.
    Could my pH really be that low?
    If so, what should I do? More borax? Bite the bullet and pay for Soda Ash? Lye?
    Thanks,
    Matt
    (I've also dumped probably over 50 lbs of Cholrine shock in over the last couple days, and still can't hold a non-zero free chlorine reading - could the pH mess up the strips?)
    Default Re: Super low pH (and other problems)
    1. Get a good testkit -- the HTH 6-way is available locally at some Walmarts; otherwise buy a cheapie OTO kit. Regardless, order a K-2006 (info page in my sig)
    2. A pH READING of 6.8, on your kit does NOT mean "6.8 exactly"; it means "6.8 OR BELOW". You'll get the reading with pH 5.0, 6.0 and 6.8.
    3. Use borax, 4 boxes at a time, added slowly to the skimmer every 4 hours. Drop back to 2 boxes at the first sign of pH increase. You can also buy "Washing Soda" -- soda ash -- at most Walmarts. Borax is preferable, but soda ash is a stronger base and you should use it if you clean out the store's borax before you get your pH up.
    4. We have seen many, many cases of biodegradation of CYA (stabilizer) to ammonia this year. The leftover ammonia creates a HUGE chlorine demand. If you have an ammonia strip, you can get an estimate of how far you still have to go, but we've seen pools take 120 ppm of chlorine to clear the ammonia. (The only other option is drain and refill, which is usually NOT an option for inground liner pools.) Try to use an unstabilized chlorine for clean up. On your pool, 7 gallons of PLAIN 6% household bleach would be about 15 ppm of chlorine. That's a reasonable nightly dose for you. Test your chlorine in the AM; when you hold chlorine over night, you are getting close to being done.
    May 2012
    Pennsylvania
    Got the HTH 6-way, 12 boxes of Borax and 20 Gallons of clorox.
    Ran the HTH pH and cholrine tests, and, surprise, surprise, the pool held 2 ppm chlorine all day (after the strip read 0 this morning, I put about 2 lbs of shock in, so I'm thinking the strips were wrong all along), and the pH was so low I could barely tell the difference between the pH solution and the chlorine solution (it was that yellow). Added 4 boxes of borax, waited a few hours, and retested - pH had moved to almost 6.8, maybe a bit lower. I just added two more boxes of borax, and 4 gals of bleach (I didn't add the whole 7 because I wasn't starting from 0).
    I feel like the pool is on its way to balance - thank you so much!
    Post full HTH test results: chlorine, pH, alk, calcium, stabilizer!
    May 2012
    Pennsylvania
    pH = 6.8 (this has actually been making progress - the mixture color now matches the 6.8 color on the kit, instead of being way yellower)
    Cl = 2 ppm
    TA = 80 ppm
    Hardness = 110 ppm
    CYA = 95 ppm
    Good deal.
    But, with a CYA=95, you need to raise your chlorine level to AT LEAST 5 ppm, and if there's the slightest bit of algae, to 10 or 15 ppm. You'll need the K-2006 to measure those levels accurately, but you can approximate with the OTO test, where orange-y yellow = ~15 ppm, and orange = ~ 30 ppm
