Re: first complete test - does this sound right?
My pool is very clear now.
I ran my areators over night...problem was the wind blew hard overnight and lowered my pool below the skimmer and the pump was sucking air this morning. So I had to add about 6 inches of water today!!
The tap water at my house appears to be high in Ph and ALK? Does that sound right? Cause my PH and ALK are not going/staying down.
My numbers just now are -
FC about 2
PH 7.5
ALK 160
CAL 200
CYA up to 29 (from 20)
temp 67
So I am adding more bleach - about 2.5 gallons per calc. Is the pool really supposed to be using 13 ppm per day?
About 30 oz of acid to lower the ph to about 6.9 per calc.
What should I get the CYA up to?
How is the Cal number for my fiberglass pool?
I think the first few times I did not get the color of the cal test up to a real blue - how blue should it be - the first time it was kind of blue with tiny red flakes in it?
thanks Kevin
