Re: Water does not appear to be filtered very well
Give it a little while to cool off and then try to turn it on. Sometimes it will try to turn until it trips whatever breaker is supplying it (have you checked the breaker to see if it's thrown?). If after a couple of hours the breaker is still on, and the pump won't turn on, it unfortunately looks like time for a new motor. Fortunately, you can probably just replace the motor and not the whole pump. On a good note, if you do have to replace it, you can put a smaller motor on it and save quite a bit of money and fix your filtration problems at the same time!
