Results 1 to 10 of 12
Thread: How often do you backwash a sand filter?
    May 2012
    WA
    Default Re: How often do you backwash a sand filter?
    Good to know, thanks! We have some warm weather coming up (for us anyway, mid 70's, lol) so we will run the filter/pump so we can heat our pool back up. We typically drop it down to mid 70's when we aren't swimming and a few days prior we turn up the degrees to heat the pool. From now on we will run it daily for 10 hrs or so and then turn it off.
    doughboy 24x24 AG round 16,100 gal with 3.5 and 6.5 deep end. Doughboy sand filter. Doughboy 1 hp pump. Tropi-cal 75k btu heat pump.
    10 hours per day should be just fine.
    May 2012
    WA
    Got it. Thanks.
    I have a two-speed pump and I run it on low for 12 hours a day. On high, less, but I rarely use high speed.
