Thread: new pump install
    May 2012
    Conneticut
    Default new pump install
    I just had to replace my hayward 1&1/2 motor and pump. I see the grounding lug on the outside of the motor. What is the the proper way to ground/or not. It was not used before. This is an in-ground 50k pool, 230volts connected to a GFI in the panel
    BigDave's Avatar
    Default Re: new pump install
    The lug on the side of the pump is to be connected to the pools bonding system. Similar to ground but different ina significant way: The bonding system of a pool connects all electrical equipment, metal parts in or near the pool, as well as the pool water itself with a low resistance conductor of sufficient size to equalize any voltage that may be in / around the pool. This is for the safety of your swimmers and is intended to prevent elecrocution.
    You should have connected the ground cable with the electrical hook up.
    I don't know how to advise you if your pool was contructed without proper bonding - perhaps you can tell us more about your pool, how you came by it.
  1. Labor cost to install pool pump
    By coachelladoug in forum Pool Equipment & Operations
    Last Post: 11-14-2011, 10:08 AM
  2. New pump install problems-help
    By Garvacious in forum Pool Equipment & Operations
    Last Post: 02-21-2009, 01:49 AM
  3. Need help for pump install Tomorrow PIC!
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-12-2006, 04:23 PM
  4. Hayward Northstar pump install: Review
    By pj1016 in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 11:46 PM
  5. How do install a timer for pump?
    By jenmenke in forum Pool Equipment & Operations
    Last Post: 05-04-2006, 11:48 PM
