Results 1 to 10 of 35
Thread: New to Forum
    Default Re: New to Forum
    Quote Originally Posted by crazy cat lady View Post
    Ben,
    I got the stabilizer today and made a slurry with hot water and the 4 lb jug and added to the pool. I hope you meant add 4 pounds at once. I'm reading the posts and according to the stabilizer label in my pool 4 lbs would get me to approximately 100ppm.
    How did you arrive at this conclusion? Didn't you tell us above that your CYA level was 0? In a 13,000 gallon pool, 4 lbs. of CYA will only add 40ppm, not 100.
    May 2012
    Watermon,
    Kem Tek label says to add 10ppm add 1/2 pound so that would be 40 ppm but the chart for 2 lbs says its 50ppm so x2 would be 100 no?A bit confusing. So I'm ok then at 40. I also added 182 oz of bleach . I was at zero before the addition after I registered 5-10 on my kit. Reading was the same this morning ph was 6.8. I added another 182 oz of bleach to get it back up to shock level per Janets response earlier. I'l brush and vacuum when I get home tonight hopefully the greenish pool is a reflection from debris below . Thanks
    24' round 13,500 gal AG vinyl pool; Haywood sand filter 1 hp s180t; ; HTH 6 Way OTO Drops; NW NJ
    If your pH is 6.8, you need to add some Borax to get it above 7.0. Add a half a box slowly to the skimmer while the pump is running, breaking up any clumps. Let it circulate for a couple hours, retest and re-dose until you get the pH somewhere between 7.2-7.8 with 7.4-7.6 being what I like best.
    May 2012
    Watermom, ph dropped after I added the cya was holding at 7.2.How big a box of Borax? I've seen the larger boxes not sure the size.Got into the pool tonight and vacuumed out 2 large loads of gunk, dead algea, pine needles.I filled 2 cartridge filters and clogged the whole hose 2x's. Had to give up after an hour as I only had 3 cartridges on hand and washed 2 out and put the clean one in to filter for the night. Chlorine was holding at the 5-10 on my kit after I added a second 182 oz jug this morning.Put another 182 in for the night.With 364 oz today I should get back up to shock level in a bit. Gonna need a bigger vacuum lol
    I've only ever seen one size box of Borax sold in all the years I've owned a pool. It is around 4lbs.
    I just re-scanned this entire thread and unless I missed it, I don't see where you have told us what kind of test kit you are using. You need to do yourself a favor and buy a Taylor K-2006. See the test kit page in my signature.
    May 2012
    Watermom,
    I'm using the hth 6 way test kit I found at Walmart last year. I added half a box of borax last night with the usual bleach and this am the ph was 7.2 after pouring all last night. Chlorine was 5-10 dark yellow.
    Pool is holding some chlorine as I go from very dark yellow 5-10 during the day( morning reading) I then add another 182 oz of bleach after the sun goes down to get me above the test kit limits . I add bleach when the level is at the 5-10 .I'm staying pretty high most of the day. Do you think I should add a second bottle at night to keep way above the test limits? I didn't locate the distilled water yet I'm in a rural area so I have to hop around different stores.
    I added the other half a box of borax this morning and added the next dose of bleach did a retest about an hour after the additions and the chlorine is orange/ red an the ph was purple 8.2 is the highest on my kit so probably above that but I just added the bleach so not concerned it will come down a bit later.
    So far I have put in the 4 lbs of cya and 4 lbs of borax. I'm brushing daily and was only able to vacuum 2 days ago when I took a ton of stuff out of the pool. Water is a very light green looks like lots floating, running the filter 24/7 and switching out the cartridge daily. New Unicels will be here by wed so hopefully I make more progress. I'll keep vacuuming as the weather permits. Don't want to be in the pool with a metal pole during a thunderstorm lol. Any other suggestions to clear this faster? I did add a dose of clarifyer earlier in the week per Bens suggestion. Do I add more? Thanks!!
    Hi CCL;
    If you would, please fill out the two forms below (#1 & #2)
    1. Pool Chart Form
    2. Pool History Entry Form
    3. Pool History Results
    We've been running into problems this year with long similar threads -- yours is one of the shorter ones -- and it's hard for the moderators and support team members to keep track of the details of each pool. Using these forms will make it easier for us, AND it will give you a place to keep your pool records. In the 3rd link above, you can see the data I extracted from your earlier posts.
    Regarding your pool, if you have green floaty stuff, you need to brush some more AND keep the chlorine very high -- orange-red (30 - 40 ppm) is a good level. If you hold that high chlorine AND brush, you should have your pool switched to cloudy gray, from cloudy green, within 24 - 36 hours.
