Re: Taylor Fas-DpD Test Kit K-2006
PoolDoc
Sounds like you're good to go!
You'll need to get some stabilizer in there. If you have a Sams Club nearby, and have access, one easy way is to buy their 24lb box of dichlor shock, for about $2.50/lb (at least, that's what they charge here
So I should get this shock and use all 24#'s immediately? What about maintenance shock, use the same stuff or just the chlorine pucks and/or bleach?
Thanks Sam
20x40 IG vinyl liner; 300lb sand filter with a 1 HP pump
