Thread: White flakes on pool bottom
    May 2012
    Texas
    Default White flakes on pool bottom
    I have a 20,000 gal in-ground, self cleaning, concrete salt water pool with a chlorination cell. I vacuum weekly, and I'm getting a white flakey substance on the bottom of my pool. Is this calcium and what can I do about it?
    Default Re: White flakes on pool bottom
    It probably is calcium--but if you'll post a set of test results (drop-based, no strips please!) for Cl, TA, pH, CH, CYA, somebody should be able to look at them and make a better diagnosis....
    Welcome to the forum!!
  1. White flakes in pool
    By cscannon in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-29-2012, 11:55 PM
  2. White Flakes
    By mknbob in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-02-2011, 11:20 AM
  3. White flakes in pool and spa
    By Txpoke in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2011, 09:44 AM
  4. White flakes in water
    By steveinaz in forum Dealing with Alkalinity and Calcium
    Last Post: 06-30-2010, 09:44 AM
  5. White Flakes????
    By sewzhmkr in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-03-2006, 01:19 AM
