Results 1 to 8 of 8
Thread: Problem with backwashing filter
    Orlando, Florida, USA.
    Default Re: Problem with backwashing filter
    If this is a "new" gunite/plaster pool you may have a problem with plaster dust coating the filter.
    I have a DE filter so I don't know if this applies to sand too ... but when I first opened my new pool I had a similar experience where I had to backwash often. The first backwash dumped a lot of dirty water. After that, the next time I'd backwash the water would flow out clear and return the pressure back to normal for only a few days before I needed to backwashed again. After a coupkle of weeks of this disassembled the filter and found the filter grids covered with plaster dust. Teh backwashing was not removing this dust (paste). I was able to wash the palster off the grids with a garden hose. I never had that problem again after that.
    jnorris is offline Registered+ Thread Analyst jnorris 0
    Florence, SC
    Quote Originally Posted by mshumack
    It's a vinyl pool. My husband now says the water coming into the pool from the returns and jets has decreased since the pressure has gone up. After we backwashed the other day, we had good pressure and could have the returns, the jets at the steps, the jets in the swim-out, and the deck jets all running with lots of bubbles. Now there is hardly any ripple.
    PB is coming out tonight to check.
    Judy
