Results 1 to 10 of 61
Thread: Cloudy.. impatient
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default Re: Cloudy.. impatient
    Quote Originally Posted by chuck9997 View Post
    Maybe I am impatient.. and my common sense keeps saying just stay the course.. keep adding bleach. Anyway.. pool was pretty green 4 days ago.. Now on the 4th day off adding bleach and running pump 24/7. Water has turned (for the better) from farm pond green to an inviting blueish white. I am happy with the results.. but seems like it is taking along time this year. Water is cloudy, I am waiting for that "I can see the bottom" clear look.
    I feel your pain. My water looked exactly like your water a few days ago. I have been adding enormous amounts of chlorine to my pool for 3 days and I finally can just barely make out my center drain in the deep end. My plan is to stay the course, as has been suggested.
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    Just remember that it didn't get in that condition overnight, and it won't clear overnight...Patience!!!!
    Tennessee.
    thanks everyone for confirming my thoughts.. btw.. ALK is only about 40 .. this will probably affect my pH.. and how much BORAX i need to add... I have added 4 pounds.. will check tomorrow morning. Should I be overly concerned about ALK in this pool. (above ground, vinyl)
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    Apr 2012
    Texas
    It will get better the longer you run the filter You've only been at it for 4 days. It could take weeks to get it totally clear....it will get there.
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
    Tennessee.
    I hope someone will notice this thread again,.. and comment I am a bit concerned... Its been SHOCK level.. and adding bleach day and night for 10 or 11 days. STILL CLOUDY.. any other suggestions?
    getting tired of spending $10 a day for bleach.
    tonight:
    todays readings:
    FC 15ppm
    CC just a trace .5
    PH 7.2
    CYA 30-40
    ALK 80
    I have done this for about 5 years.. and always get clear water by day 3 or 4.. what is the problem?
    BigDave's Avatar
    You have measureable CC so you need to maintain shock level - there's still a fight in there. Have you measured how much FC you lose overnight? Is your filter pressure climbing? Have you had to backwash it? (only when pressure rises 8-10 above clean)
    Don't know why this year is different, maybe the warm winter. Lots of people are opening with huge chlorine demand this year, likely from bioconversion of CYA to ammonia.
    (is bioconversion a word?)
    Tennessee.
    thanks for the response BigDave.. from last night lost 3ppm FC. Filter pressure is ok.. Through the process.. I have backwashed a couple of times.
    I will stay with it..
    raised back to 15ppm this AM
    using 6% bleach (182 ounce jugs).. each should raise about 6ppm. Its a 24ft round AG pool. (about 14000 gallons)
    So.. am I shooting for 0 CC? Would a slight CC reading (1ppm this morning) cause the cloudiness?
    The water is pretty clean.. nice. I have been in the pool (even at shock level) to sweep, etc. Just not clear. I put the little robot car vacuum in yesterday... and could just barely see it on the bottom of the pool.
    May 2012
    Buffalo, NY
    The only comment I can add here is that you have to follow what they are saying to do TO THE LETTER. I was in your shoes about a week ago where my water was blue but cloudy. I was feeling impatient too but I stayed the course and followed the advice given here TO THE LETTER and I was rewarded with perfectly clear pool water. Keep at it!
    Muskegon, Michigan
    tonight:
    todays readings:
    FC 15ppm
    CC just a trace .5
    PH 7.2
    CYA 30-40
    ALK 80
    Hi Chuck- It took me 3 weeks to get my pool clear. I've been following the teachings of this site for 6-7 years and last year was the first time I had issues with cloudy water over an extended period of time. It usually took me 3-4 days, like you, to get it clear by shocking and running the pump 24/7. I too believe the issue this year (at least for me) was the lack of winter (80 plus degrees in March), and a load of oak leaves in my pool (my neighbors monster oaks are coming down some night!). At any rate, you'll get there, just stay the course. Did I mention it took me THREE WEEKS to get my pool clear? Just hang in there.
    Michigan (Go Blue!), 18X36 IG Vinyl, 20,000 gal, 3/4 H.P. Sta-Rite Pump, Purex Triton "Tagelus" TA-60/60D Sand Filter (325 lbs.), 200M Purex Triton Minimax plus pool heater. Using old PS232 Kit and purchase Taylor refill chems.
    Tennessee.
    Quote Originally Posted by Guppy View Post
    very similar situation as myself.. thanks for responding. Do you mind telling me how it finally worked out? I am algae free and am letting the FC drift down a little. I have always been the kind of pool owner who ran the FC a little higher than needed.. probably just a mind game I play with myself. I am running the pump all the time.. have a skimmer sock in place and a little DE in the sand filter.
    I really think the pool is clearing.. but its soooooo slow. did you use anything other than filtration? Any skimmer socks, DE, clarifiers?.. etc??
  1. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 06:09 PM
  2. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 06:55 PM
  3. BROWN/GREEN POOL due to Impatient Husband
    By muleheaded in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-11-2008, 06:51 PM
