Results 1 to 10 of 61
Thread: Cloudy.. impatient
    Tennessee.
    Default Re: Cloudy.. impatient
    CarlD recommend polyquat to you in this thread and I asked if you'd considered it. You've probably read about it elsewhere as well.
    Polyquat is an algecide but works best to prevent rather that kill algae. Polyquat also can act as a clarifier and should help clear the water. Keep a close watch of your FC if you do decide to use polyquat. As Watermom pointed out: the polyquat will create a chlorine demand and you don't want to start another algae bloom.
    OK.. thanks for all the help so far.. just updating. Water is clean.. but still cloudy. All readings have been remaining normal and steady.
    I have found PLOYQUAT 60.. and bought a quart. If someone reads this tonight.. please let me know how much I need to add. (24ft round AG pool - approx 14000 gal, give or take) Meanwhile I will doa little searching. I suppose I should add POLYQ in front of the return?
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    It's been a long time since I've used any polyquat so I had to look up the dosing information. What does it say on the label? I believe, unless it has changed, that the dosing is 9 oz. per 10,000 gallons of water. Please look at the label and see if that is correct and let me know. And yes, you can add it in front of the return. You also might want to put your filter on recirculate for awhile so it doesn't filter out so fast.
    Tennessee.
    exactly right Watermom! I found it on here as well. the label also says about the same thing (depending on before or after algae dosage). I added 14 ounces in front of the return and set the filter to circulate. I'll check FC in the morning and bump it up some.
    Good deal.
    Tennessee.
    Last night, just before adding POLY-Q, I poured in enough 6% bleach to bring FC level to about 9. This morning.. checked FC.. it's at 8. So POLY-Q didn't eat too much overnight. I will dose with a little more bleach before going to work.. just to make sure I don't fall too low with the daytime sun.
    CLOUDY: I am pretty sure the PQ is doing something.. I ran the pump on recirculate for a few hours (after adding). Been running on "filter" for about 8-9 hours. The water is clearer than last night. I am hoping for more improvement when I get home from work tonight. Maybe we can close this thread,.. finally. I will let you know.
    (by the way.. had to buy POLY-Q at pool store.. $23 for a quart)
    Yes, please do let us know how it works. And, continue to keep an eye on your chlorine levels.
    Tennessee.
    Came home tonight.. pool water is even better. I know there isn't a silver bullet to solve all problems.. it's doing all the things right,.. but I am impressed with the POLY-Q. Since adding PQ 24 hours ago.. the difference is dramatic. It isn't "crystal".. but it's pretty damn clear! Might be "crystal" clear tomorrow. I put a skimmer sock back in.. that usually polishes the water some.
    Also.. I noticed that the PQ didn't seem to eat the bleach as much as I thought it would.
    One question.. if the water doesn't become any clearer tomorrow.. would it help to add any additional PQ? Or is there a limit as to how it can act as a clarifier?
