Results 1 to 10 of 61
Thread: Cloudy.. impatient
    Default Re: Cloudy.. impatient
    Your water looks great! So glad you shared the pics and really glad that you finally got it cleared up.
    I agree with bumping your CYA up to 40 or 50. In my pool, I typically add bleach every other day but sometimes daily. Depends on how many people have been swimming, or if there have been storms dropping debris in the pool or how hot and sunny it has been.
    Wondering -- did you add more than one dose of the Polyquat or just the one?
    Tennessee.
    I only added the one dose (14 ounces). The water cleared even more the 2nd day.
    Glad I didn't add more.. two reasons:
    I don't like putting much of anything, other than bleach in my water..
    and.. PQ is about 70 cents an ounce.. I still have more than half a quart left (in case I need it next spring).
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    Tennessee.
    thats almost $90 a gallon.. glad my car runs on $3.50 a gallon gas.
    BigDave's Avatar
    Nice!
    Congrats and thanks!
    Water looks fantastic--good job!!
    I run my pool with a CYA of 80-90 ppm because I find that I blow through way too much chlorine if I try to keep it below that--with it at 90, it enables me to add the larger size jug of WalMart bleach to my (roughly) 25K gallon pool every 2nd or 3rd night, unless we've had a heavy swimmer load that day. Try bumping yours up a little, see what you think about the chlorine loss, and then raise it as high as you need to to optimize your chlorine. If you only bump it up by 10-20 ppm at a time, it won't be so high that you can't lose some of it through backwashing or splashout if you overshoot a little bit...
