Thread: Oak trees and pools: like hair and chewing gum
    May 2012
    Glen Allen, Virginia.
    Default Oak trees and pools: like hair and chewing gum
    I have an above ground pool and we are getting it installed this week. I want to put it in the most level area of my yard wich would put it partially under a pin oak tree. I know I will get the ocassional leaf or small twig in the pool. My question is, will the pool being under the tree cause any water quality issues from leaves or sticks getting in the pool? Thanks for any help on this.
    Default Re: New member with question
    The only real problem I can see with the sticks is the possibility that they'll poke holes in the liner, but if you're diligent about keeping them out, then you'll probably be okay. Water-wise it won't cause too much of a problem. I think you're going to get more than the occasional leaf in the pool, though--make sure you have a really good vacuum!!
    Welcome to the forum!!
    Default Re: Oak trees and pools: like hair and chewing gum
    + 100 - 200 acorns in fall
    + many small twigs (pin oaks shed them)
    + pin oak leaves high in tannins can stain your pool
    Here the US FS page: http://plants.usda.gov/factsheet/pdf/fs_qupa2.pdf
    Trees with acorns and oak leaves go together with pools, like hair and fresh chewing gum. You'll be getting very skilled with a hand vacuum and a leaf net.
    Apr 2012
    Texas
    If you are diligent about cleaning out the sticks & leaves it is manageable. My parents pool is directly under a sweet gum, which is a real pain in the behind, because it drops leaves in late summer and sweet gum balls (sharp pointy balls).
    On our pool, we have to deal with pine trees. The needles are awful because they are thin enough to go through the skimmer basket and get into the pump impeller.
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
    BigDave's Avatar
    Default Re:Oak trees and pools: like hair and chewing gum
    My AG is under pin oaks. In the sping, they drop flowers (I think they're flowers) then tons of pollen and pollen strings. Little (and sometimes big) sticks all year long. Leaves and acorns all summer and fall. Leaves continue to fall 'til January.
    My solution: Robot Cleaner - realtively cheap and picks up almost everything the trees drop in (except big sticks).
  1. Green Hair Problem After Using Bioguard Smart Shock
    By SnoopysGirl in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-16-2012, 05:19 PM
  2. Trees that are pool friendly
    By waste in forum General Interest
    Last Post: 04-30-2011, 02:18 PM
  3. NEVER put a pool up under trees!!! HELLLP!
    By denanbob in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-03-2010, 07:53 PM
  4. What causes green hair?
    By jnorris in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-29-2006, 11:13 PM
  5. Green Hair????
    By readytoscream in forum Dealing with Alkalinity and Calcium
    Last Post: 06-13-2006, 08:08 PM
