Results 1 to 4 of 4
Thread: High CYA
    May 2012
    North Carolina
    Post High CYA
    Does CYA deteriorate during the summer or is the only way to lower it is by dilution?
    Default Re: High CYA
    It does not deteriorate during the summer--if you lose any during summer, it's usually due to splashout, backwashes, leaks, etc. Draining and refilling water is the only REAL way to lower it.
    It does occasionally deteriorate during the winter, in pools that are allowed to go swampy, but in those cases, the byproducts create huge chlorine demands on opening, so that's not a good option!!
    Welcome to the forum!
    Quote Originally Posted by aylad View Post
    It does occasionally deteriorate during the winter, in pools that are allowed to go swampy......
    And, sometimes even in pools that do not go swampy.
    Janet, Watermom;
    The degradation of CYA to ammonia is 1 of 3 possible routes. It can also go to nitrogen gas (no problem) or nitrates (no immediate problem), and in my own experience, one of those two is the most common. I assume that the weather this winter somehow is related the very high frequency of the CYA=>NH3 events, but I don't really know.
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 11:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 05:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 01:09 PM
